08-02-2018, 01:56 AM
HI Steve,
When you say the bores have been honed was this done with a parallel or deglazing hone
the bores after honing should have a distinctive Crosshatch Pattern this can only be obtained by slow rotation and vertical movement .
At the moment what you have are glazed bores.
they will need to be done again using a parallel hone.
if you do not have the gear take it to your nearest Engine Shop they should be able to do this with out dismantling the Engine
Hope this is of some help
Colin
Colin
