Clutch Release Bearing Lubrication
I am presently building bits to go back on an RP saloon, and have the gearbox and clutch release parts on the bench. I have always believed that the oiler tube lubricated the release bearing. However, as far as I could see, the oiler tube connects to a drilling in the bearing carrier that simply delivers oil to the front gearbox cover to lubricate the bearing carrier on the front cover. I could not see any side drilling hole to take oil to the actual bearing. It is very difficult to see down the oil hole to be certain.
I would agree with John's assessment, the 4-speed was a sealed bearing and the oiling is purely for the movement along the shaft. Seems to be an odd arrangement for a car built in the 1930's, guess it was difficult to provide a means to adequately lubricate & this was their solution. I think the "holes" in the bearing are dimples to secure the two halves together.
The arrangement of the 3-speed is different, where the oiler provides for what is a small reservoir in the release bearing hosing and as the bearings spin around the rotation of the oil supply leaks through the drilling onto the shaft to provide lubrication for the movement.
Clutch Release Bearing Lubrication - by Jamie - 05-06-2021, 07:24 PM
RE: Clutch Release Bearing Lubrication - by Jamie - 06-06-2021, 09:49 AM
RE: Clutch Release Bearing Lubrication - by GK5268 - 07-06-2021, 07:20 PM
