06-06-2021, 10:01 PM
When you push the cutout closed it will or should lock closed. Must pull open or release by disconnecting the battery briefly.
Contacts can be cleaned as above. The ignition bulb should vaguely approximate the originall bulb or combination.
Not clear which lead you put the ammetr in. But assuming the summer resistor is not on the dynamo, if ammeter in the lead from dyn it supplies some current for its own field independant of the cutout operation.
