Riser Plate for Block
John Barlow shims are .5mm or .75mm = 20 or30 thou he is not very quick at answering emails phone 01159220680. When fitting shims do not use a gasket coat both sides of shim with sealant, I use ThreeBond 1215. Terry.
You can use 2 shims if the top of block has been machined.
Riser Plate for Block - by Jamie - 03-06-2021, 06:33 PM
RE: Riser Plate for Block - by Colin Wilks - 03-06-2021, 06:40 PM
RE: Riser Plate for Block - by Ruairidh Dunford - 03-06-2021, 06:48 PM
RE: Riser Plate for Block - by Steve Jones - 03-06-2021, 06:52 PM
RE: Riser Plate for Block - by Jamie - 03-06-2021, 06:54 PM
RE: Riser Plate for Block - by Ruairidh Dunford - 03-06-2021, 07:44 PM
RE: Riser Plate for Block - by Jamie - 03-06-2021, 09:00 PM
RE: Riser Plate for Block - by Chris KC - 03-06-2021, 09:09 PM
RE: Riser Plate for Block - by Jamie - 03-06-2021, 11:54 PM
RE: Riser Plate for Block - by Chris KC - 04-06-2021, 08:39 AM
RE: Riser Plate for Block - by Tony Betts - 04-06-2021, 08:41 AM
RE: Riser Plate for Block - by Jamie - 04-06-2021, 09:08 AM
RE: Riser Plate for Block - by Nick Lettington - 04-06-2021, 11:47 AM
RE: Riser Plate for Block - by Chris KC - 04-06-2021, 12:13 PM
RE: Riser Plate for Block - by Jamie - 04-06-2021, 12:34 PM
RE: Riser Plate for Block - by Nick Lettington - 04-06-2021, 02:35 PM
RE: Riser Plate for Block - by Terrytuned - 04-06-2021, 02:47 PM
RE: Riser Plate for Block - by Nick Lettington - 04-06-2021, 02:48 PM
RE: Riser Plate for Block - by Stuart Giles - 04-06-2021, 05:30 PM
RE: Riser Plate for Block - by JonE - 04-06-2021, 09:34 PM
RE: Riser Plate for Block - by Ian Williams - 04-06-2021, 09:53 PM
RE: Riser Plate for Block - by Chris KC - 04-06-2021, 10:24 PM
RE: Riser Plate for Block - by Jamie - 03-07-2021, 12:26 PM
