04-06-2021, 11:47 AM
(This post was last modified: 04-06-2021, 11:56 AM by Nick Lettington.)
Jamie. Its not something I have done, but was considering a block skim to restore the height of valve seats... when you refer to the paper gasket not being an option, where are you expecting to put the shim plate? I suspect you will need to disturb the paper gasket!
To make that a little clearer... the shim goes underneath the block... you will need to remove the block to fit it.
