How to remove window winder handle.
(06-02-2018, 10:49 AM)Robert Leigh Wrote:
(06-02-2018, 09:49 AM)Austinsixandahalf Wrote: 1930 Mulliner Box saloon with suicide doors.
Sorry to ask the answer to what I feel sure is a simple question. How do you remove the winder handle? Do you carefully prise it off, and therefore is there a spring clip either on the handle or the spindle. Thank you.
Having seen your recent pictures I have to say that I do not recognise the handle, but You may find a small catch on the back which needs moving along the axis of the handle by pushing with a suitable implement such as a screwdriver, to actuate a locating collar which holds the handle on the spindle.
Robert Leigh
Thanks Robert. I am familiar with 60’s classics, where there is a handle, with a separate spring collar, and a pin into the winder shank - but this is completely different. Will investigate further!
RE: How to remove window winder handle. - by Austinsixandahalf - 06-02-2018, 11:06 AM
RE: How to remove window winder handle. - by JonE - 15-07-2019, 08:40 PM
