No start!
#25
(26-05-2021, 11:48 AM)Eddamoo Wrote: If the exhaust is blocked, it should be pretty apparent on the restart as the car should struggle to even crank with the increased back pressure, shouldn't it?  10 seconds is a lot of gas volume so id be doubtful it would take that long for the engine to cut out.  Should be easy to see with a lack of visible vapour and exhaust pressure on startup?
Ed, not Austin seven but I have attended maybe a dozen cars with blocked exhausts. They crank normally. They start normally. Usually they will tick over all day, not cut out. There is nothing unusual to see at the exhaust pipe. The engine will speed up to a fast tickover but little more. Just won't rev much. If you floor the accelerator and hold it there, the exhaust has a distinctive whooshing/hissing sound.
No start! - by 12jslater - 25-05-2021, 07:39 PM
RE: No start! - by Colin Wilks - 25-05-2021, 08:33 PM
RE: No start! - by 12jslater - 25-05-2021, 08:41 PM
RE: No start! - by andrew34ruby - 25-05-2021, 08:55 PM
RE: No start! - by Robert Leigh - 25-05-2021, 09:44 PM
RE: No start! - by 12jslater - 25-05-2021, 09:50 PM
RE: No start! - by David Stepney - 25-05-2021, 10:08 PM
RE: No start! - by 12jslater - 25-05-2021, 10:19 PM
RE: No start! - by Howard Wright - 26-05-2021, 07:37 AM
RE: No start! - by 12jslater - 26-05-2021, 07:59 AM
RE: No start! - by John Cornforth - 26-05-2021, 08:08 AM
RE: No start! - by Colin Wilks - 26-05-2021, 08:16 AM
RE: No start! - by Duncan Grimmond - 26-05-2021, 08:27 AM
RE: No start! - by andrew34ruby - 26-05-2021, 08:27 AM
RE: No start! - by 12jslater - 26-05-2021, 08:33 AM
RE: No start! - by Malcolm Parker - 26-05-2021, 08:57 AM
RE: No start! - by 12jslater - 26-05-2021, 09:04 AM
RE: No start! - by John Mason - 26-05-2021, 09:12 AM
RE: No start! - by Bob Olive - 26-05-2021, 10:22 AM
RE: No start! - by Eddamoo - 26-05-2021, 11:48 AM
RE: No start! - by 12jslater - 26-05-2021, 12:44 PM
RE: No start! - by jpsmit - 26-05-2021, 01:11 PM
RE: No start! - by Tony Griffiths - 26-05-2021, 01:32 PM
RE: No start! - by 12jslater - 26-05-2021, 04:09 PM
RE: No start! - by andrew34ruby - 26-05-2021, 04:37 PM
RE: No start! - by Duncan Grimmond - 26-05-2021, 06:07 PM
RE: No start! - by Andy Bennett - 26-05-2021, 06:17 PM
RE: No start! - by John Cornforth - 26-05-2021, 06:28 PM
RE: No start! - by 12jslater - 26-05-2021, 07:10 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:21 PM
RE: No start! - by 12jslater - 26-05-2021, 07:26 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:40 PM
RE: No start! - by David Stepney - 26-05-2021, 09:26 PM
