No start!
Have you tried disconnecting the fuel pipe to the carb and plugging the end to stop leaks then fit a small say 1/2 pint of petrol temporary take to the carb and see if it will run for longer. If this works you know it’s a fuel problem but further back down the line from the carb. If it is no better at least you know the pump is ok. You say you get a good spark from the plugs so it appears the ignition is ok. That only leaves fuel and if you have done the test I have already suggested the carb OR a mechanical problem but you seem convinced compression is there which suggest valves and rings are ok. My bet is it’s a fuel problem not enough or too much. You say your plugs are wet so that’s makes me think too much.
If I was you I would start afresh and re check everything I have done we are all prone to sometimes missing the obvious.
John Mason.
No start! - by 12jslater - 25-05-2021, 07:39 PM
RE: No start! - by Colin Wilks - 25-05-2021, 08:33 PM
RE: No start! - by 12jslater - 25-05-2021, 08:41 PM
RE: No start! - by andrew34ruby - 25-05-2021, 08:55 PM
RE: No start! - by Robert Leigh - 25-05-2021, 09:44 PM
RE: No start! - by 12jslater - 25-05-2021, 09:50 PM
RE: No start! - by David Stepney - 25-05-2021, 10:08 PM
RE: No start! - by 12jslater - 25-05-2021, 10:19 PM
RE: No start! - by Howard Wright - 26-05-2021, 07:37 AM
RE: No start! - by 12jslater - 26-05-2021, 07:59 AM
RE: No start! - by John Cornforth - 26-05-2021, 08:08 AM
RE: No start! - by Colin Wilks - 26-05-2021, 08:16 AM
RE: No start! - by Duncan Grimmond - 26-05-2021, 08:27 AM
RE: No start! - by andrew34ruby - 26-05-2021, 08:27 AM
RE: No start! - by 12jslater - 26-05-2021, 08:33 AM
RE: No start! - by Malcolm Parker - 26-05-2021, 08:57 AM
RE: No start! - by 12jslater - 26-05-2021, 09:04 AM
RE: No start! - by John Mason - 26-05-2021, 09:12 AM
RE: No start! - by Bob Olive - 26-05-2021, 10:22 AM
RE: No start! - by Eddamoo - 26-05-2021, 11:48 AM
RE: No start! - by 12jslater - 26-05-2021, 12:44 PM
RE: No start! - by jpsmit - 26-05-2021, 01:11 PM
RE: No start! - by Tony Griffiths - 26-05-2021, 01:32 PM
RE: No start! - by 12jslater - 26-05-2021, 04:09 PM
RE: No start! - by andrew34ruby - 26-05-2021, 04:37 PM
RE: No start! - by Duncan Grimmond - 26-05-2021, 06:07 PM
RE: No start! - by Andy Bennett - 26-05-2021, 06:17 PM
RE: No start! - by John Cornforth - 26-05-2021, 06:28 PM
RE: No start! - by 12jslater - 26-05-2021, 07:10 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:21 PM
RE: No start! - by 12jslater - 26-05-2021, 07:26 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:40 PM
RE: No start! - by David Stepney - 26-05-2021, 09:26 PM
