No start!
(26-05-2021, 08:08 AM)John Cornforth Wrote: Hi
There is also the remote possibility that the exhaust system is partially blocked, which will build up back pressure.
The symptoms for a blocked exhaust are generally that it will start and tick over all day, but not rev much.
(26-05-2021, 07:59 AM)12jslater Wrote: its definitely compression, the engine will just suddenly run worse, refuse to rev and cut out over a couple of seconds.
Try dribbling petrol into the air intake during that couple of seconds. It sounds like a shortage of petrol, so might be worth feeding the carb from a bottle hung above, to eliminate the tank, pipe and pump.
No start! - by 12jslater - 25-05-2021, 07:39 PM
RE: No start! - by Colin Wilks - 25-05-2021, 08:33 PM
RE: No start! - by 12jslater - 25-05-2021, 08:41 PM
RE: No start! - by andrew34ruby - 25-05-2021, 08:55 PM
RE: No start! - by Robert Leigh - 25-05-2021, 09:44 PM
RE: No start! - by 12jslater - 25-05-2021, 09:50 PM
RE: No start! - by David Stepney - 25-05-2021, 10:08 PM
RE: No start! - by 12jslater - 25-05-2021, 10:19 PM
RE: No start! - by Howard Wright - 26-05-2021, 07:37 AM
RE: No start! - by 12jslater - 26-05-2021, 07:59 AM
RE: No start! - by John Cornforth - 26-05-2021, 08:08 AM
RE: No start! - by Colin Wilks - 26-05-2021, 08:16 AM
RE: No start! - by Duncan Grimmond - 26-05-2021, 08:27 AM
RE: No start! - by andrew34ruby - 26-05-2021, 08:27 AM
RE: No start! - by 12jslater - 26-05-2021, 08:33 AM
RE: No start! - by Malcolm Parker - 26-05-2021, 08:57 AM
RE: No start! - by 12jslater - 26-05-2021, 09:04 AM
RE: No start! - by John Mason - 26-05-2021, 09:12 AM
RE: No start! - by Bob Olive - 26-05-2021, 10:22 AM
RE: No start! - by Eddamoo - 26-05-2021, 11:48 AM
RE: No start! - by 12jslater - 26-05-2021, 12:44 PM
RE: No start! - by jpsmit - 26-05-2021, 01:11 PM
RE: No start! - by Tony Griffiths - 26-05-2021, 01:32 PM
RE: No start! - by 12jslater - 26-05-2021, 04:09 PM
RE: No start! - by andrew34ruby - 26-05-2021, 04:37 PM
RE: No start! - by Duncan Grimmond - 26-05-2021, 06:07 PM
RE: No start! - by Andy Bennett - 26-05-2021, 06:17 PM
RE: No start! - by John Cornforth - 26-05-2021, 06:28 PM
RE: No start! - by 12jslater - 26-05-2021, 07:10 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:21 PM
RE: No start! - by 12jslater - 26-05-2021, 07:26 PM
RE: No start! - by Reckless Rat - 26-05-2021, 07:40 PM
RE: No start! - by David Stepney - 26-05-2021, 09:26 PM
