SM5 Switch Panel. Anyone repair them ?
Thank you jonE,
I do the brass strip. £4.00 each. Saves hours of work trying to cut your own out.
But not the resistance wire, as far as I understand the wire is there to dull the bulb down.
So you can still Use the 6 volt bulb, without the wire rapped round it. It will just be alot brighter.
Tony
RE: SM5 Switch Panel. Anyone repair them ? - by Tony Betts - 05-02-2018, 08:13 PM
