17-05-2021, 09:52 AM
Jake,
Assuming that you have bought the three bearing Ruby you mentioned earlier, it should be running on 4.00 (or 4,50) X 17 rims and tyres. 4.00 X 17 tyres rotate at approx 800 revs per mile, giving 14.29 mph per 1000 engine revs is top and 4.50 X 17s at 785 revs per mile, giving 14.56 mph per 1000 rpm.
3.50 X 19 rims and tyres rotate at 775 revs per mile, giving 14.75mph per 1000 rpm.
So, not much variation. Assuming the standard 5.25:1 diff, 45mph represents about 3000 rpm in top.
Austin Seven engines always sound busy: my RP (on 5.25:1 diff and 3.50 X 19 rims) is just this at 40 -45 mph, but has covered a lot of miles running at this sort of speed. A well sorted engine is really quite robust.
Hope this helps and gives some perspective on engine speed.
