Changing ring and pinion gears
(16-05-2021, 07:04 PM)12jslater Wrote: How easy would it be to change the differential ratio for a slight lower over all gearing, 1st gear seems very short in a seven and useless 2nd gear hill starts are easily possible so I was looking at getting a bit more top end speed, just being able to sit at 45mph with a lower engine speed than what feels like a million rpm.
I'm not looking for any more speed just lower revs when I travel long journeys.
Hope to hear your thoughts
With the gearing set up to give lower revs at speed I think you'd find there just isn't enough power. At the slightest incline you would be running in third gear much of the time. Forever dropping down a gear.
Remember you need power to maintain speed, and power is turning force multiplied by revs. You need revs to keep you going.
I find it easier to drive at 35, with resultant less revs, but think it would be better with a slightly lower gearing so changing into third less often.
jslater, do you live in a very flat area?
Changing ring and pinion gears - by 12jslater - 16-05-2021, 07:04 PM
RE: Changing ring and pinion gears - by JonE - 16-05-2021, 07:23 PM
RE: Changing ring and pinion gears - by 12jslater - 16-05-2021, 07:42 PM
RE: Changing ring and pinion gears - by JonE - 16-05-2021, 07:48 PM
RE: Changing ring and pinion gears - by andrew34ruby - 17-05-2021, 08:52 AM
RE: Changing ring and pinion gears - by Dave Mann - 17-05-2021, 10:24 AM
RE: Changing ring and pinion gears - by Steve kay - 18-05-2021, 08:55 AM
