11-05-2021, 06:08 PM
Hi Reckers
Yes. I had huge problems getting the float level right. This isn’t the final incarnation (the float chamber ended up on the other side!) but it gives you an idea of the need to drop the float level using the aluminium cylinder. The manifold is a first attempt. I brazed the T and flange on but I wasn’t happy and had it professionally Tig welded.
