10-05-2021, 12:52 AM
It looks as if, once the 1st motion shaft and bearing are removed, and the rear bearing and housing also removed, the 3rd motion shaft should slip back sufficiently for the whole assembly to be removed from the top of the box. The taper could then be dealt with on the bench with either a suitable puller or press.
