  • 1 Vote(s) - 1 Average
Grub Screws to set Clutch Toggle Lever Height
Thank you for the advice, Terry. I have assembled it properly now and measured the height. The are all between 1.27" and 1.30" above the clutch plate, so just need a little more grinding off. They have been built up with weld at some time and I have had to grind them flat as the weld was rather bobbly.
The rollers make a huge difference. On the bench without them fitted, I could not move the clutch by hand. With the rollers in, I can start to depress the clutch with pressure from one finger.
Regards,
Jamie.
RE: Grub Screws to set Clutch Toggle Lever Height - by Jamie - 09-05-2021, 06:28 PM
