  • 1 Vote(s) - 1 Average
Grub Screws to set Clutch Toggle Lever Height
An update.
I have now fitted 5.5mm rollers underneath the lever arms. Does anyone know whether the tips of the fingers which operate on the release bearing should be above or below the face of the main flywheel plate through which the fingers protrude? This is the plate which is bolted on with the six bolts. What distance or height should the finger tips be in relation to the plate?
Regards,
Jamie
RE: Grub Screws to set Clutch Toggle Lever Height - by Jamie - 09-05-2021, 11:34 AM
Users browsing this thread: 18 Guest(s)
