Thetis Engine Nosecone Removal
Does anyone know how to remove the Nosecone on a Thetis Marine engine?
I've removed the five ' regular' bolts that secure it to the crankcase but in order to pull it off the crankcase I think the cylindrical part at the end of camshaft (where the Fan Pulley would normally be) needs to be removed. I can't get to the nut on the end of the camshaft, which I assume is holding this part in place, without removing the water pump but can't remove the water pump because I can't get to one of the lower nuts which secures the pump to the nosecone.
Sorry if this question makes no sense but if you have tried to do this before you might understand what I'm trying to explain!
Thanks,
Paul
.jpg   Thetis Nosecone.jpg (Size: 42.95 KB / Downloads: 230)
Thetis Engine Nosecone Removal - by Paul Lawrence - 08-05-2021, 08:53 AM
RE: Thetis Engine Nosecone Removal - by dickie65 - 08-05-2021, 09:04 PM
