Advice to Remove Dynamo
There are two bolts that bolt the Dynamo to the Aluminium casting that go in from the passemger side of the vehicle.
They are 1/4 BSF you will need a 3/16 whitworth socket to access them a 3/8 drive set is recommended.
The bolts may have screw driver slots cut in them at some time so they are removable with a flat screw driver.
There is also a long bolt that goes down the back of the aluminium casting this has to be removed on some generators before removal.
Advice to Remove Dynamo - by Graham Barker - 06-05-2021, 11:11 PM
RE: Advice to Remove Dynamo - by David Grear - 07-05-2021, 03:04 AM
RE: Advice to Remove Dynamo - by Dave Mann - 07-05-2021, 08:55 AM
RE: Advice to Remove Dynamo - by Graham Barker - 07-05-2021, 10:17 AM
RE: Advice to Remove Dynamo - by Bob Culver - 07-05-2021, 10:45 AM
RE: Advice to Remove Dynamo - by Dave Mann - 07-05-2021, 02:06 PM
RE: Advice to Remove Dynamo - by Parazine - 07-05-2021, 10:49 PM
RE: Advice to Remove Dynamo - by Bob Culver - 08-05-2021, 02:17 AM
RE: Advice to Remove Dynamo - by Colin Cooke - 08-05-2021, 07:42 AM
RE: Advice to Remove Dynamo - by Graham Barker - 08-05-2021, 10:47 AM
RE: Advice to Remove Dynamo - by john williams - 08-05-2021, 11:38 AM
RE: Advice to Remove Dynamo - by David Stepney - 08-05-2021, 01:33 PM
RE: Advice to Remove Dynamo - by Graham Barker - 12-05-2021, 10:27 AM
RE: Advice to Remove Dynamo - by Martin Baker - 12-05-2021, 05:15 PM
RE: Advice to Remove Dynamo - by Dave Mann - 13-05-2021, 08:11 AM
RE: Advice to Remove Dynamo - by Martin Baker - 13-05-2021, 12:32 PM
