Throttle return spring
I have a second spring simply to eliminate play in the linkage.
It runs alongside the vertical link from the lever on the bulkhead to the throttle spindle.
On Reckless's picture that's the top end of spring 2 on to the spindle.
I find that the linkage needs careful adjustment to ensure that both full throttle and fully closed are achieved.
My carb is the updraught 22FZ
The aluminium casting on the top of the column is usually worn which makes getting it to move smoothly and stay put in the right place difficult.
The springs/screw assembly are available.
Throttle return spring - by Erich - 03-02-2018, 04:26 PM
RE: Throttle return spring - by Reckless Rat - 03-02-2018, 04:39 PM
RE: Throttle return spring - by Erich - 03-02-2018, 04:47 PM
RE: Throttle return spring - by Reckless Rat - 03-02-2018, 05:24 PM
RE: Throttle return spring - by Steve Jones - 03-02-2018, 05:46 PM
RE: Throttle return spring - by Erich - 03-02-2018, 05:54 PM
RE: Throttle return spring - by Ruairidh Dunford - 03-02-2018, 06:20 PM
RE: Throttle return spring - by Erich - 03-02-2018, 06:35 PM
RE: Throttle return spring - by AustinWood - 03-02-2018, 07:04 PM
RE: Throttle return spring - by Ruairidh Dunford - 03-02-2018, 07:41 PM
RE: Throttle return spring - by Tony Press - 03-02-2018, 10:06 PM
RE: Throttle return spring - by Ruairidh Dunford - 03-02-2018, 10:36 PM
RE: Throttle return spring - by Tony Press - 04-02-2018, 12:51 AM
RE: Throttle return spring - by Erich - 04-02-2018, 04:45 AM
RE: Throttle return spring - by Erich - 05-02-2018, 05:53 PM
RE: Throttle return spring - by Geoff Halstead - 12-02-2018, 02:44 PM
RE: Throttle return spring - by Erich - 13-02-2018, 07:31 PM
RE: Throttle return spring - by Ruairidh Dunford - 13-02-2018, 07:45 PM
RE: Throttle return spring - by Reckless Rat - 13-02-2018, 07:59 PM
RE: Throttle return spring - by Steve Jones - 13-02-2018, 08:32 PM
RE: Throttle return spring - by Malcolm Parker - 13-02-2018, 08:48 PM
RE: Throttle return spring - by Erich - 15-02-2018, 05:38 PM
