Floor-mounted starter button and choke control
(03-05-2021, 12:10 PM)Mike Costigan Wrote: The RM also has the choke cable through the steering column mounting. What does the choke swivel on the front of the bulkhead look like, Tony? Cars with the choke on the passenger's side have the swivel bolted directly through the bulkhead, so one 1/4" hole in the bulkhead, whilst the later cars have the swivel mounted onto an angled bracket with two smaller holes (0BA or 3/16"?).
Thanks, both. That makes sense; as the wire passing through the bulkhead does not go straight through (as on earlier cars) but is at a considerable angle, the swivel bracket must be as yours, Mike. I never had the original choke pull on my PL 3002 Chummy - but there are two holes that appear to be correct. Of course, the last hyper-bodger owner managed to lose the steering column clamp and the replacement is without the required hole. Do you have a picture of the arrangement as the wire passes through the column clamp? Might it have a large hole for a brass sleeve to pass through, with a slot beneath to let the wire drop into?
RE: Floor-mounted starter button and choke control - by Tony Griffiths - 03-05-2021, 01:09 PM
