29-04-2021, 09:50 AM
Wheel bearings best not externally lubricated. Can stir up what is there with a thick wire. I dunno about the 3 speed box but most recommend running 4 speed boxes and diffs somewhat low. Needs very occasional checking whether used or not. if in use kingpins and shackles esp rear cannot be overgreased. No permanent battery drain as infuriating moderns but some method of maintaining charge required. A n inhibitor in radiator important. If no frost risk there are less expensive types available. Avoid starting the car just to move it. Condensation bad for main bearings and exhaust system.
