Big ends
Are you sure that the caps are matched with the rods to which they were originally fitted? I have hand scraped 10 thou undersized big ends to fit a new shaft; it takes time but it's cheaper and quicker than sending them for remetalling. Old rods often have hacksaw marks to identify 1,2,3&4. In such cases I reject them. If you plan to use full revs as I do they are not safe from breakage. When scraping to fit I tighten the rod dry onto the shaft to the point where it will just turn; after one turn the white metal is marked at the tightest points where a small amount of white metal needs scraping off. Repeat until it feels just slightly tight to turn when the bolts are fully tightened. At that stage loosen a bit and apply oil to the bearing before retightening. If you have things right the rod will just fall slowly under its own weight from horizontal; if not a little more scraping is needed until the gravity test works. If any of your rods will not tighten to turn without wobble they need remetalling.
Big ends - by Steve kay - 28-04-2021, 08:48 PM
RE: Big ends - by David Stepney - 28-04-2021, 09:05 PM
RE: Big ends - by Howard Wright - 28-04-2021, 09:11 PM
RE: Big ends - by Robert Leigh - 28-04-2021, 09:41 PM
RE: Big ends - by Chris KC - 28-04-2021, 10:17 PM
RE: Big ends - by Colin Reed - 28-04-2021, 10:22 PM
RE: Big ends - by Bob Culver - 28-04-2021, 11:56 PM
RE: Big ends - by Stuart Giles - 29-04-2021, 09:16 AM
RE: Big ends - by Hedd_Jones - 29-04-2021, 11:01 AM
RE: Big ends - by Chris KC - 29-04-2021, 12:33 PM
RE: Big ends - by Hedd_Jones - 29-04-2021, 03:04 PM
RE: Big ends - by Steve kay - 29-04-2021, 09:25 PM
RE: Big ends - by Chris KC - 30-04-2021, 08:31 AM
RE: Big ends - by Bob Culver - 30-04-2021, 09:44 AM
RE: Big ends - by Steve kay - 30-04-2021, 09:10 PM
