Positive or negative earth on a rewire?
(26-04-2021, 07:58 PM)Ivor Hawkins Wrote: Thanks fellas, I’ve made sure I have a good earth from the cut out and checked it with a meter and I have managed to sort out the cut out wiring, the extra wires go to the auxiliary fuse for the horn and electric windscreen wiper.
Now can anyone tell me if the wiring for the rear lamps and fuel gauge runs under the car or inside, I’ve completely forgotten!
Ivor, Down the outside just inside the drivers side lower sill that the running board is bolted to. I know this, as my car has several little steel clips bolted to the body at this position to take the cables.
RE: Positive or negative earth on a rewire? - by David Stepney - 26-04-2021, 08:42 PM
