Oil jet blockage
Hi All
This thread has got me thinking.  I have a bored out pump and a standard 10 psi gauge.  On start up pressure is off the gauge, hot running also off the gauge, hot tickover around 2 psi.
So how would I know if I have a blocked jet? At normal running the gauge is showing 10 psi and on the stop!
So I’ve bought a pressure switch that will close contacts between 4 and 29 psi (adjustable). The idea being to install a warning light to light when the pressure reaches a certain value. I will T in the switch in the oil line to the gauge.
 My question, at what pressure should I set the switch?  I’m thinking about 20psi?  The light would then be on at start up.....go out as the oil heats up... and light up again if 20 psi is reached.
Oil jet blockage - by Peter Naulls - 24-04-2021, 10:06 PM
RE: Oil jet blockage - by Robert Leigh - 24-04-2021, 10:50 PM
RE: Oil jet blockage - by Howard Wright - 25-04-2021, 07:54 AM
RE: Oil jet blockage - by Nick Turley - 25-04-2021, 10:43 AM
RE: Oil jet blockage - by Hedd_Jones - 25-04-2021, 03:21 PM
RE: Oil jet blockage - by Peter Naulls - 25-04-2021, 05:35 PM
RE: Oil jet blockage - by Chris KC - 25-04-2021, 09:57 PM
RE: Oil jet blockage - by Greig Smith - 26-04-2021, 05:47 AM
RE: Oil jet blockage - by Howard Wright - 26-04-2021, 10:45 AM
RE: Oil jet blockage - by David Grear - 26-04-2021, 12:58 PM
RE: Oil jet blockage - by Ruairidh Dunford - 26-04-2021, 01:06 PM
RE: Oil jet blockage - by Howard Wright - 26-04-2021, 07:04 PM
RE: Oil jet blockage - by Peter Naulls - 26-04-2021, 09:22 PM
RE: Oil jet blockage - by Ruairidh Dunford - 26-04-2021, 09:33 PM
RE: Oil jet blockage - by JonE - 26-04-2021, 09:36 PM
RE: Oil jet blockage - by Ruairidh Dunford - 26-04-2021, 09:38 PM
RE: Oil jet blockage - by Peter Naulls - 26-04-2021, 09:39 PM
RE: Oil jet blockage - by Howard Wright - 26-04-2021, 09:57 PM
RE: Oil jet blockage - by Peter Naulls - 26-04-2021, 10:04 PM
RE: Oil jet blockage - by Eddamoo - 28-04-2021, 04:29 PM
RE: Oil jet blockage - by Howard Wright - 10-05-2021, 06:24 PM
