Dave - That wouldn't work (Would it?). The main tap shuts off ALL fuel (Reserve and main). Under normal tank conditions, fuel can flow through just the main (Main being the one with the tube). If the reserve tap is shut, then when the top of the tube is in free air, fuel delivery stops. If you swapped the tube about, the tube would then be on the port for the reserve and you wouldn't get fuel unless both the main and reserve taps were open. You wouldn't know that you were running low until you had run out (I think).
RE: What have you done today with your Austin Seven - by bob46320 - 22-04-2021, 02:18 PM
