21-04-2021, 09:17 AM
ok thankyou - so split the case, remove it all from N/S for visual check? After presumably removing the torque tube stuff which will stop it coming out. And then check for basic soundness.
But as you say, if it's shims, then as long as they go in as taken out, all stays the same... and an opportunity to clean down insides with spray can oil or diesel etc?
