16-04-2021, 05:42 PM
Hi All
And thanks for the replies. I will leave it until I change the engine oil at 500miles and put a magnet in the drain plug (I’ve got one on the engine sump!). I’ve only done 170miles so far and changed the engine oil at 50 and 100. I plan the next engine oil change at 250 and then 500. (Splash fed, gauze filter).
The car seems to be running well although is quite tappety, probably because of the reground followers. I may have the manifolds off and check the tappets when I do the 250 mile oil change.
