diagnosing a blocked radiator??
#41
I take it all back!!!!
I figured I might as well fit the rad back on and give it a try, as I don't have a replacement yet.
It is very clearly improved, and is good enough at this time of year:
As a guide to others, if you have any signs of oil in the water, I would start with water based de-greaser (I used GUNK) - I think this did the most work improving things.
The rad still needs replacing I think, as there are a few leaks (hard water for a while may fix those), and it's unlikely to cope in the summer (the water is reaching 80 odd with moderate uphill work), but it was good fun experimenting!
diagnosing a blocked radiator?? - by jamesheath - 11-02-2021, 10:07 PM
RE: diagnosing a blocked radiator?? - by Rick F - 12-02-2021, 01:29 AM
RE: diagnosing a blocked radiator?? - by John H - 12-02-2021, 12:41 PM
RE: diagnosing a blocked radiator?? - by JonE - 12-02-2021, 01:20 PM
RE: diagnosing a blocked radiator?? - by Rick F - 12-02-2021, 03:36 PM
RE: diagnosing a blocked radiator?? - by John H - 12-02-2021, 05:47 PM
RE: diagnosing a blocked radiator?? - by David.H - 13-02-2021, 07:09 PM
RE: diagnosing a blocked radiator?? - by JonE - 12-03-2021, 09:02 AM
RE: diagnosing a blocked radiator?? - by A G Wood - 12-03-2021, 09:45 AM
RE: diagnosing a blocked radiator?? - by Renaud - 12-03-2021, 09:57 AM
RE: diagnosing a blocked radiator?? - by Parazine - 12-03-2021, 10:00 AM
RE: diagnosing a blocked radiator?? - by jamesheath - 14-04-2021, 01:16 PM
