Propshaft clattering at higher speeds
My last fabric coupling lasted all of 1200 miles before it broke up, and I decided to 'bite the bullet' and fit a Hardy Spicer propshaft (ex Ruby). It really turned out to be a 'Fit and Forget' solution and I must have done 20,000 Plus miles with no further trouble. You will need the matching gearbox and rear axle pinion shaft flanges, and as has been mentioned before you will need to modify the handbrake mountings. Not difficult if you use countersunk high tensile screws.
Suggest you contact Tony Betts (he supplied my bits in 2014) as a first resort.
Good luck with the replacement.
Bob
RE: Propshaft clattering at higher speeds - by Bob Kneale - 11-04-2021, 05:08 PM
