09-04-2021, 06:41 PM
Further diagnostics.... the solid wire from the 4th field coil to third brush was broken by the time it was disassembled.
Reading the corrected resistance for the coils from this wire to the external F terminal stud, on a decent meter, was only 2.0/2.1, so not a great deal more than the commonly low readings of the (2 coil) C35 models - something to consider if you are wanting to run an electronic regulator which needs 2.5/3.5.
The worksmanship inside the CAV unit is a cut above the Lucas offerings. Incredibly neat and purposeful. Bearings either end.
