Stuck Woodruff Key
Do not apply localised heat to your crankshaft.
The technique I generally employ is to slowly 'worry' it out with taps from different directions. Once you get a little movement going more will slowly follow. Apply leverage or a drift under any overhang if there still is one. Try striking from above (with a drift) to rock it in its groove. Persevere. If truly stuck you may have to resort to machine tools e.g. drill it through, and it still might put up a fight. But it's one of those cases where you should exhaust the least aggressive methods before you up the ante.
Stuck Woodruff Key - by Jamie - 08-04-2021, 10:21 AM
RE: Stuck Woodruff Key - by Chris KC - 08-04-2021, 11:07 AM
RE: Stuck Woodruff Key - by Jamie - 08-04-2021, 11:23 AM
RE: Stuck Woodruff Key - by Chris KC - 08-04-2021, 11:27 AM
RE: Stuck Woodruff Key - by Howard Wright - 08-04-2021, 11:28 AM
RE: Stuck Woodruff Key - by Jamie - 08-04-2021, 11:31 AM
RE: Stuck Woodruff Key - by Rick F - 08-04-2021, 11:34 AM
RE: Stuck Woodruff Key - by Alan - 08-04-2021, 12:29 PM
RE: Stuck Woodruff Key - by Jamie - 08-04-2021, 05:45 PM
