'I found that once I'd put Longstones on the front recently dropping the pressure to 25psi instead of the 30psi I was using in the Avons improved things'
I have always been advised that Avon tyres should only ever be be inflated to 22 psi
RE: What have you done today with your Austin Seven - by Tony Press - 07-04-2021, 11:18 PM
