6V Ducellier regulator advice? (Dauphine era)
Hi Jon
The fraught applies to all models, due the field being intended for just 4 or 5 volts.. Been extensively covered in the past. The only complexity of the DEL is the internal resistor if still intact, and your wiring effectively bypasses it anyway. Whatever, as with all the dyns, keeping the output within accepted amps is the main consideration.
At least for those without a full grasp of the workings I very strongly concur with John's recommendation.
RE: 6V Ducellier regulator advice? (Dauphine era) - by Bob Culver - 03-04-2021, 07:43 PM
