Thanks, guys. Jeff, Failed to mention new front hoses. Yes, I have the front holes in the disc to adjust snails, 2 cylinders in each wheel. How tight should the brake shoes be against the disc. mine is set to almost touching. Got my wife to sit in the car and hold the brake down and with a bit of effort and the car jscked just off the ground i could turn both wheels using the same strength so once rolling nothing there.
Good brake fluid flow when bleeding. Bleed nipples at the front facing down.
