Loctite 28654 Thread Repair
If you've got access to a lathe, Colin its well worth turning a guide bush for the tap [similar idea to a drill guide] and try to seat it on the washer face to help keep the tap square. There looks to be a lot of lead on that eBay tap so you mightn't have to do any drilling.  Also, further to Stuart's tap turner it's also possible to drill out a suitable sized nut and press it onto the squared end/silver solder it onto the squared end and use a socket which makes it slightly easier to get everything square, especially if you can get a tee-handle on there.
Loctite 28654 Thread Repair - by Colin Wilks - 25-03-2021, 08:59 PM
RE: Loctite 28654 Thread Repair - by Chris KC - 25-03-2021, 10:18 PM
RE: Loctite 28654 Thread Repair - by Stuart Giles - 25-03-2021, 11:14 PM
RE: Loctite 28654 Thread Repair - by Colin Reed - 26-03-2021, 12:26 AM
RE: Loctite 28654 Thread Repair - by Colin Wilks - 26-03-2021, 08:03 PM
RE: Loctite 28654 Thread Repair - by Steve Jones - 26-03-2021, 08:35 PM
RE: Loctite 28654 Thread Repair - by Colin Wilks - 26-03-2021, 10:37 PM
RE: Loctite 28654 Thread Repair - by A G Wood - 27-03-2021, 03:39 AM
RE: Loctite 28654 Thread Repair - by Colin Wilks - 27-03-2021, 11:58 AM
