21W tungsten flasher relay/shotky diode issues
Do you know if your flasher unit is electronic? If the flashers work OK when the motor's not running, but misbehave when it is, it's could be because the electronics in the flasher unit are suffering from interference from unsuppressed/insufficiently suppressed plug leads.
RE: 21W tungsten flasher relay/shotky diode issues - by Stuart Giles - 26-03-2021, 11:37 AM
