19-03-2021, 11:51 PM
Most accurate way is the positive stop method, piston on stop from both ways, marking flywheel periphery each time and and bisecting. There is a lot of 'dwell' at the TDC which makes it hard to get accurate results, even with a DTI. Piece of flat with a bolt threaded into it works fine if the head is off.
