Brake Switch to Pedal Linkage
It is a small bracket made of body gauge steel which wraps around the pedal to cross shaft link rod. A tension spring from this bracket attaches to the pull rod on the switch. The bracket is a friction grip on the link rod. To adjust the bracket you loosen the screw on the bracket which provides the friction grip.
Brake Switch to Pedal Linkage - by RupertW - 17-03-2021, 10:08 PM
RE: Brake Switch to Pedal Linkage - by Dave Wortley - 17-03-2021, 10:58 PM
RE: Brake Switch to Pedal Linkage - by RupertW - 18-03-2021, 09:42 PM
