differences in interior water channels in blocks?
Plus 2 for the hacksaw blade approach - that & a length of curtain rod spiral wound cable which I ran at fast speed in my battery hand drill, this tended to find its own way into nooks & crannies. I didn't get a lot more crud out, but definitely shifted some in the corners
Short lengths of curtain rod spiral wound cable & paraffin work wonders to remove crud from crankshaft oil holes. Slow speed on the electric drill & back & forth from all ends. Finish with a good flush of paraffin & compressed air. Top Tip - do this over several layers of newspaper, you would be amazed at what comes out of so-called "clean cranks'
Aye
Greig
RE: differences in interior water channels in blocks? - by Greig Smith - 17-03-2021, 09:13 PM
