Raglan Little John lathe?
#28
I had a little Chinese lathe I used to make little things on. Small steam engines and parts for my little props and gadgets. I 'upgraded' to a Emco which isn't much bigger but more solid and better built. Still not big enough but it has been invaluable with my Riley 9 build once I set it up for thread cutting. I've made a gearbox mount and the rear suspension mounts and other things for it. I am getting far more confident on what I can do now.
The Emco was missing most of the change gears so I 3D printed a set (first in PLA then in Nylon which is much stronger) and it works very well. But it is a faff having to manually change gears (it's not the gearbox version unfortunately) and not having a thread indicator is very annoying. I have to stop the lathe, pull the tool back to a known mark then reverse the carriage all without disengaging the lead screw. Once my move is complete I can foresee an upgrade to a bigger machine one day.
And that still won't be big enough...
Simon
Raglan Little John lathe? - by merlinart - 07-02-2021, 12:55 PM
RE: Raglan Little John lathe? - by Dave Wortley - 07-02-2021, 12:57 PM
RE: Raglan Little John lathe? - by Jacob Fowkes - 07-02-2021, 01:10 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 02:01 PM
RE: Raglan Little John lathe? - by Charles P - 07-02-2021, 02:13 PM
RE: Raglan Little John lathe? - by bob46320 - 07-02-2021, 02:15 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 02:18 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 03:03 PM
RE: Raglan Little John lathe? - by Chris Garner - 07-02-2021, 04:21 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 04:28 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 05:14 PM
RE: Raglan Little John lathe? - by Lowespeed - 07-02-2021, 05:14 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 05:22 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 06:37 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 07:52 PM
RE: Raglan Little John lathe? - by Bob Culver - 07-02-2021, 11:27 PM
RE: Raglan Little John lathe? - by jr2766 - 12-02-2021, 12:32 AM
RE: Raglan Little John lathe? - by merlinart - 14-03-2021, 07:36 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 14-03-2021, 07:48 PM
RE: Raglan Little John lathe? - by merlinart - 14-03-2021, 07:53 PM
RE: Raglan Little John lathe? - by Steve kay - 14-03-2021, 08:39 PM
RE: Raglan Little John lathe? - by Bob Culver - 16-03-2021, 01:45 AM
RE: Raglan Little John lathe? - by Charles P - 16-03-2021, 03:28 AM
RE: Raglan Little John lathe? - by Bob Culver - 16-03-2021, 08:20 PM
RE: Raglan Little John lathe? - by jansens - 17-03-2021, 02:22 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 17-03-2021, 03:43 AM
RE: Raglan Little John lathe? - by Bob Culver - 17-03-2021, 09:19 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 17-03-2021, 10:25 AM
RE: Raglan Little John lathe? - by Charles P - 17-03-2021, 01:58 PM
RE: Raglan Little John lathe? - by Bob Culver - 17-03-2021, 07:04 PM
RE: Raglan Little John lathe? - by jansens - 17-03-2021, 08:31 PM
RE: Raglan Little John lathe? - by Reckless Rat - 17-03-2021, 09:32 PM
RE: Raglan Little John lathe? - by jansens - 18-03-2021, 04:21 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 18-03-2021, 10:19 AM
RE: Raglan Little John lathe? - by Parazine - 18-03-2021, 10:44 AM
RE: Raglan Little John lathe? - by Dave Mann - 18-03-2021, 12:08 PM
RE: Raglan Little John lathe? - by Charles P - 18-03-2021, 12:42 PM
RE: Raglan Little John lathe? - by Ivor Hawkins - 18-03-2021, 02:42 PM
RE: Raglan Little John lathe? - by Bob Culver - 18-03-2021, 03:09 PM
