  • 1 Vote(s) - 5 Average
Front çrank bearing lip replacement
(19-08-2017, 05:47 PM)Derek Sheldon Wrote: I
A stripped down block becomes an excellent parallel. It was the only way to get enough head room to drill out for the set screws. Hole was started will a drill and completed with a mill
Hello Derek, now confused, 1st picture shows holes being drilled from inside, this picture shows being drilled from outside.
In the past I have drilled through the 4 1/4 whit holes with the tapping size drill, then tapped right the way through, easier than tapping from inside.
Your finished job looks excellent, I like the use of the A7 block as a parallel.
RE: Front çrank bearing lip replacement - by Zetomagneto - 19-08-2017, 09:22 PM
