14-03-2021, 02:08 PM
(This post was last modified: 14-03-2021, 02:58 PM by Ruairidh Dunford.)
From memory:
A Girling Front axle requires:
4 - 5/16 BSF x 1/2" for the brake adjusters
8 - 5/16 BSF x 5/8" for the back plates
4 - brass castellated 1/4 BSF nuts for the actuators.
8 - 3/8 BSF nuts for the damper links
4 - 3/8 BSF nuts for the spring shackles
2 - 1" 3/8 BSF bolts for the damper to front chassis bracket
2 - 1/4 bsf 1 1/4" bot for drag link cups
All other fasteners are specific to A7s and can be found here: https://www.theaustinsevenworkshop.com/c...d-steering
and here: https://www.theaustinsevenworkshop.com/c...ts-chassis
Girling rear axle requires:
6 - 5/16 BSF x 5/8" for the back plates
2 - 5/16 BSF x 5/8" for the back plates beside spring pin cotter
2 - 5/16 BSF x 1 1/2" for torque tube anchor ball adjuster
12 - 5/16 x 1" for torque tube and side tube
4 - 1/4 BSF x 1/2" for side adjuster covers
Rear axle A7 specific fasteners are here: https://www.theaustinsevenworkshop.com/c...ansmission
Girling type chassis
4 - 1/4 BSF x 1/2" for centre brake cross shaft bearing housing
If you are using the original cow horns you will also require:
2 - 3/8 BSF x 1"
2 - 3/8 BSF x 1 1/4"
I think that is it, I may have missed something so feel free to add...
2 - 3/8 BSF x 1"
