10-03-2021, 07:33 PM
Hope this is clear enough Peter,In hindslght I would have used larger section angle and thicker channel instead of extra box section on the outside. Each channel is bolted on with 8 M8 bolts plus the ones bolting the angle to the H section. I purchased the 1050 wide ramp as the Ulster only has 2 1/2" ground clearance to the front brake cross shaft and the ramp is 5" high I think.
