Fuse Wire
In a previous role of school science teacher I used to demonstrate fuses by hooking an about 3cm piece of the fuse wire in series with a power supply, a variable resistor(rheostat), and an ammeter, all standard items in a science classroom. With the rheostat at its maximum I would switch on and gradually decrease the resistance until the fuse, to generally muted excitement, melted - noting the amps when it did so. The fuse wire (which I would guess was British) reliably melted within an amp or so of its advertised value.
I would imagine that there isn't a non-destructive method of finding the value of an unmarked fuse, although visual comparisons with fuses of known values may give a guide.
Fuse Wire - by williamsderbys - 23-01-2018, 06:52 PM
RE: Fuse Wire - by Nick Turley - 23-01-2018, 07:04 PM
RE: Fuse Wire - by Tony Press - 24-01-2018, 12:04 AM
RE: Fuse Wire - by David.H - 24-01-2018, 10:13 AM
RE: Fuse Wire - by Ritchie Wilson - 24-01-2018, 11:06 AM
RE: Fuse Wire - by Stuart k - 24-01-2018, 10:51 PM
RE: Fuse Wire - by Tony Press - 25-01-2018, 07:13 AM
RE: Fuse Wire - by Stuart k - 26-01-2018, 09:46 AM
RE: Fuse Wire - by Zetomagneto - 26-01-2018, 10:00 AM
RE: Fuse Wire - by andrew34ruby - 26-01-2018, 11:41 AM
RE: Fuse Wire - by Parazine - 26-01-2018, 10:07 AM
RE: Fuse Wire - by Stuart k - 26-01-2018, 10:17 AM
RE: Fuse Wire - by Tony Press - 26-01-2018, 09:31 PM
