rear axle Banjo case
Dave H.  I'd be surprised if, having scraped everything away, that you don't find more details on the banjo, as I've never seen a diff that didn't have stamped the date (day, month, year) also other numbers.  They include the 3338 you quoted which indicates the diff' numbers that re-commence with 1 from any change in design, the numbers (eg 4/44) which indicate the original cw & p, and if another letter & number's there it shows whoverput it together on the assembly line.  Hope this helps others too.   Cheers,  Bill in Oz
rear axle Banjo case - by David.H - 01-03-2021, 05:36 PM
RE: rear axle Banjo case - by Stuart Giles - 01-03-2021, 07:47 PM
RE: rear axle Banjo case - by Paul Cooper - 01-03-2021, 08:49 PM
RE: rear axle Banjo case - by David.H - 01-03-2021, 08:49 PM
RE: rear axle Banjo case - by Bill Sheehan - 03-03-2021, 12:46 AM
RE: rear axle Banjo case - by David.H - 03-03-2021, 09:42 AM
RE: rear axle Banjo case - by Howard Wright - 03-03-2021, 10:08 AM
RE: rear axle Banjo case - by David.H - 16-03-2021, 04:42 PM
RE: rear axle Banjo case - by Tony Griffiths - 16-03-2021, 08:17 PM
RE: rear axle Banjo case - by David.H - 17-03-2021, 11:09 AM
