25-02-2021, 08:41 PM
Had another go today and all went well, knowing what to expect made things easier. The thing I'm not sure about is how tight should the castle nut be? If I tighten hard up I can't put the pin through and backing it off leaves it not tight enough. Also what a duff design that split pin affair to hold the shoes back with the curly spring.
Thank You so much to you all.
RPM
RPM
