REPLACING FRONT BRAKE CYLINDERS.
You will need to pull the outer off first so that you can access the hub nut and split pin.
The inner may then lever off, or you may have to put the outer back on, if the latter put the brake drum back on with its 3 screws and wheel nuts the pull the whole lot off using your puller
REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 24-02-2021, 05:12 PM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 24-02-2021, 09:32 PM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Zetomagneto - 24-02-2021, 09:41 PM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 24-02-2021, 11:02 PM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 25-02-2021, 11:52 AM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 25-02-2021, 08:41 PM
RE: REPLACING FRONT BRAKE CYLINDERS. - by Rpm - 26-02-2021, 12:19 PM
