Q - screw-in block core plug removal
#25
(21-02-2021, 06:08 PM)Colin Wilks Wrote:
(21-02-2021, 10:24 AM)Stuart Giles wrote Wrote: Does your car have the late "heavy" rear axle? These have bigger wheel bearings than earlier cars; ISTR that the hub thread on those is 1 3/8"
Just measured internal threads on my standard Austin hub puller and the 1 3/8" x 16 tpi die that I have for refreshing the hub threads. Both measure 1.298".
Hi Colin, Perhaps I should have been clearer; hub thread as in the rear hub nut; the one that retains the LJ 1 1/4 bearing on the rear casing on all the pre heavy rear axle cars. As you say, the hub puller thread is 1 3/8" x 16 TPI.
Q - screw-in block core plug removal - by JonE - 18-02-2021, 09:02 PM
RE: Q - screw-in block core plug removal - by Stuart Giles - 21-02-2021, 07:22 PM
