20-02-2021, 07:08 PM
If you've adjusted the box up so there is no play in the straight ahead position it will tighten up on lock. If you back off the adjustment so there is about 1" play at the steering wheel rim it should be about right. Same with the column (worm) adjuster on the box. Don't overtighten it. I've done everything you have and have just had to settle for some slop.
