19-02-2021, 08:25 PM
(This post was last modified: 19-02-2021, 08:27 PM by Reckless Rat.)
Set the fronts on their own with the back cables slacked right off. Then adjust the rears. You will be amazed how slack the rear cables need to be for you to get the right balance front and rear. Use a cable spreader on the rear cables for fine adjustment. You don't want too much braking at the back otherwise they will lock under heavy braking and you could lose control, as the car will try to rotate.
